dmm reading ?
after i wired each sub to 2 ohm. theres a positive and negative wire from each sub, i connected the 2 positives together, the 2 negatives together, where it could go to the one channel on the amp. but got a low reading so never hooked it up to the amp. the dmm reading when connected the leads together says .1
That will give you a one ohm load. You wired (2) 2-ohm loads in parallel which equates to a (1) ohm load.
You need to take the positive from one sub to the dmm. The negative from that sub will go to the positive of the other sub. The negative from THAT sub will go to the DMM. That should read about 4 ohms.
Again, see: http://www.the12volt.com/caraudio/woofer_configurations.asp
Bullet03
Bullet03
Atlanta,GA
wevie
vegang
vegang
