Hows my type-r setup
plasticspoon
I bought some used 2004 type-r's from a forum member here, and was just wondering what i can expect, as i dont have time to install my deck or subs till next week..
2 12" 2005 Alpine Type-R's
1200watt MA Audio HK1998 Amp @ 1ohm x 1200 watts
Ported 5.25 cubic feet box, 33x17x17, not sure what its tuned to as the seller was unsure, (how can i find out?)
Pioneer 6800MP HU
putting these in my 2000 chevy impala ls, with a huuuuge trunk. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
umm them subs in the box are 2005 not 2004 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif since you cant tell the differnce I would have to say get a multimeter and test the impendance on your subs to make sure they are even running @ 1ohm right now //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
also is that box even ported?
i meant 2005's oops... The box is 33x11x11, ported - the two slots on the side (the black parts) the box is 5.25 cubic feet, but im not sure what its tuned to.
the slots on the box are about 2.5 inches wide each.
Learn how to use a tape measure please.
If the ports are really 2.5" wide each, then the ports are big enough.
ok do you know if the box is a single or double chamber? also measure the inside of the port width height and length, we might be able to tel you the tuning unless its a staggered port.
and prochobo you have a PM
definitely the wrong dimensions there
i can measure the ports when i get home, but the dimensions on the box are 33x17x17 ...i was in a rush when i posted that before...
im not sure if it a single or double chamber.
If those are outer dimensions, that enclosure is only ~4.4 cubic feet and that is not taking into acount the ports. The ports look to be about 1x16 or so and that is not much port area for some Type-Rs. How deep are the ports? Take them out and check and also check the wiring while you're at it. Taking out a few screws isn't painful.
plasticspoon
plasticspoon
LI, NY
xluben
vegang
vegang
