How to wire 2 dual 4 ohm voice coil subwoofers
lol., dude u said all that and said nothing, pretty awesome!!
Not talking about OP but people now a days are so lazy and just want answers with putting in no work them selfs. I want to see people learn instead of just have answers spoon feed to them all the time.
Wire everything in parallel. Both positive together on each sub and both negative together will bring sub to 2ohm. Then wire the 2 subs together, positive to pos, negative to neg. This brings you to 1 ohm.
If not for asking questions, why have a forum? Trolls gonna troll.
Here is a diagram just in case
or this one https://i.imgur.com/RTbqNjA.jpg
Wire everything in parallel. Both positive together on each sub and both negative together will bring sub to 2ohm. Then wire the 2 subs together, positive to pos, negative to neg. This brings you to 1 ohm. If not for asking questions, why have a forum? Trolls gonna troll.
44 post 2015er.. Yes you have made this forum great.
Sounds like you're out of phase...you need to switch your negative to positive. Because of this cap I usually don't comment...all kinds of comments, nothing to say.
Don't let them get you worked up... I've learned that even if the answer is seemingly off subject or even mean,
actually he had a point... do the research first...there is some entertainment value here.. oh, crud... my popcorn is burning!
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
773
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
782
CpsChase
CpsChase
Houston, TX
Buick_66
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
