indosia
I can't get the window crank off a 2008 accent. Can someone explain exactly how to use this tool? I understand there is a little c clip that is supposed to pop out. Instructions say to find the open end of the clip, but I can't even see it. I slide tool behind door crank, I push, pull, twist, turn but nothing pops out. I tried google and people say to do this and that, but it still didn't work. This car has a spacer between the window crank and the door. Should i try sliding tool between spacer and window crank. or between door and spacer?
