How to use a door/window crank removal tool ?
indosia
I can't get the window crank off a 2008 accent. Can someone explain exactly how to use this tool? I understand there is a little c clip that is supposed to pop out. Instructions say to find the open end of the clip, but I can't even see it. I slide tool behind door crank, I push, pull, twist, turn but nothing pops out. I tried google and people say to do this and that, but it still didn't work. This car has a spacer between the window crank and the door. Should i try sliding tool between spacer and window crank. or between door and spacer?
Use the hook end to pop off the CLOSED end of the clip. Use a large flat blade screwdriver to pry the handle away from the door panel, so you can see the clip better and go behind the spacer.
I ended up breaking the ****er, window crank. I guess I pushed too hard with the window crank removal tool and sheered the plastic in half. Found the c clip. It popped out. So I glued the plastic back together, but I still dont see how the clip fits and holds it on.
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
419
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
682
Tons of options in that budget, including the cost of installation,
10
993
indosia
indosia
hayward, ca
jmanpc
    Jun 1, 2024
    May 31, 2024
