How To Set Up Hpf And Lpf
JAVI
Help On The Setup, I Have An Amp 4 Channel 4x75w "focal Solid 4" With A Lpf (50-150 Hz) And Hpf (50-150 Hza) Connected To A Set Of Focal Speaker Two Way "mediums" 6.5" With A Frec Resp 60 Hz To 20 Khz For The Front Speaker, And Also A Set Of 6x9 Focal Speaker With A Frec Response 60 Hz To 20 Khz For The Rear,,the Speakers Are Focal Acces Model,,,,,,in The Other Hand I Have A 10" Subm,,but This Is Other History
Start with the high pass on all the front speakers at about 100hz, then begin to lower it until the point that you think it sound good- above the point that the speakers have a hard time playing the bass.
If you have the HPF above 60hz, you're completely safe to play with where it's set.
JAVI
JAVI
NOGALES,AZ
denim
michigan born
    May 14, 2026
michigan born
    May 14, 2026
