how to set my gain
Oscope and tone generator work well, DMM can help you with match gains on indentical amps using the wattage. I used an oscope to dial mine in. Turn the deck up full tilt, all settings flat. no speakers hooked up. See what your deck signal is. Mine was clean. no clipping. So then we Clamped the amps and put them under load and scoped them. They took 4600Watts to each sub at full tilt with the amps gain only 15% increase. This was done with a 47hz tone. the box tuned to 40hz.
Here is a step by step.
1.) Calculate the target output voltage. It's a pretty simple equation.
Output Voltage = the square root of RMS wattage X the Final ohm load.
Example: 1000 W RMS X 2 Ohms = 2000
And, the square root of 2000 is 44.72. In this example, 44.72 is the target output voltage.
2.) Set all of the controls for the bass, on the head unit and the amp, to zero. ( gain, boost, bass control)
3.) Disconnect the subs
4.) Turn off, or disconnect the mid and high range speakers in the car.
5.) With the engine running, pop in the 50hz test tone, on repeat, and crank the volume to about 3/4 of the head unit's capacity. If it goes to 40, turn it to 30. This is usually the point just before the signal will start to degrade.
6.) Set the Multimeter to AC voltage. Then see what you get for an output.
7.) Slowly turn up the gain, boost, and bass, until you reach your target voltage. On most amps, this is the point just before the amp starts to clip. Clipping causes distortion. Which will cause a ton of problems. Including the one that you have now.
8.) Turn down the volume and eject the test tone CD from the head unit.
9.) Turn everything off.
10.) Reconnect everything.
Jayy
Jayy
tampa fl
09civic
