How To Set Gains On Liar Amps
spitfirees20
i have the re boner
I've read multiple tutorials on how to set amp gains using volts, seen JL's flash tutorial, etc, and I know the basic formula to use ( Sqrt(Power*Resistance) = Voltage
(i.e. If you bridge a 4 ohm subwoofer to your amplifier that is rated to produce 100 RMS @ 4 ohms in bridged mode, you would want Sqrt(4*100) = 20 volts) ) However, there is one problem: say I have a legacy amp (like I would ever disgrace my SX like that //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif), that's rated to put out 1000 watts rms. We all know this cannot happen without major clipping. So, if I set the gains on an amp that overrates it's rms power rating according to what they rated it as rms, wouldn't that ruin my subs?
if it is clipping it will. if your amp doesn't do that power you won't reach the proper voltage when adjusting your gain //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
first find the volume level at which your headunit clips and put it at that volume..second put your amp gain at zero and bass boost at zero and your lpf at 200hz (or as high as your amps goes).....next, at the clipping volume of you hu, play a 60hz tone and increase your gain on ur amp little by little and listen in your subs for any change in sound, distortion, hissing, or any unsual sound, and leave it at the gain setting at which you clip.....that is the max your gain shud be at, and make sure, after finding the clipping volume of ur HU, never to turn it passed that volume...
/of step by step gain setting
I know how to set gain lol, I've done multiple car audio setups. I was just wondering how to do it the correct way, using volts, if the amp manufacturer lies about t/s. Thanks anyways though.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
wtf???
that is the correct way.....why care about volts when ur lookin for the MAX ouput from that amp without clipping....do what i told u and stop wasting ur time //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifwtf???
I find it EXTREMELY diffucult to detect distortion (i.e. a clipped signal) from a subwoofer.
The only way to properly do it would be with an o-scope. What amp is it that you are wondering about? Someone can most likely give you a rough estimate of its output, from experience...
spitfirees20
i have the re boner
spitfirees20
Rhode Island
iceteebone
