right amp?
Give an idea of the budget you have for the amp and it will make it eaiser for people to give you some suggestions. Obviously with two fifteens the you will need the strongest one you can afford.
I'm guessing you're wanting around 2000watts+ @ 2ohm.
Perfect for that would be to find a used (or new) DIrected audio 2400D or Viper 2500.1 those put out 2400 watts @2ohm. I'm not sure how much power those Mag's handle safely but if 1200each is fine then you'll be golden
another option is a lanzar optidrive 2000D which is .5ohm stable and should be enough power
or ALPHASONIK PMA1200DA @2ohm (2000w)
Powerbass XA3000D (2000@2)
just keep in mind the lanzer vibes are NOT anything like the opti's... there are basically the same as BOSS and other junk... stick with the OPTI's... they have a good rep... also aren't the IA 20.1's in that price range?
not under 500 as far as i know...i thought it was closer to 700
upon24s
upon24s
Staten Island, NY
loserpunk
