How to make my trunk the loudest?
I currently have a 12" Sundown Audio Nightshade and im about to put both in there and i want it to be the loudest possible. It will be in a 2010 Nissan Altima and will be ran off a DDM3A at 1 ohm. Any help would be greatly appreciated
Both what? What box do you have it in? What install work have you done?
Im saying im about to make a box for 2 of them, a 2 12" box.
---------- Post added at 11:45 PM ---------- Previous post was at 11:44 PM ----------
Hmm, for onee.. You can start off by sending me your xs power d3100 battery. That should get you pretty loud. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Tempting //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
the specs that I gave are for two of them //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Can you design me a box?
---------- Post added at 11:58 PM ---------- Previous post was at 11:58 PM ----------
What do they do at .5?
pm me. I might as well just tell you right now that designs are $25. but I own 2 nsv2 12s myself so I have some good experience with them....
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
790
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
SUNDOWNBITCH
Danville, KY
Danometal
    May 31, 2024
    May 24, 2024
