How to install a stinger voltage meter?
I was thinking about buying an installing one of the stinger voltmeters in my car (81 pontiac) and i was wondering, its just a basic pos and neg connection right? And would be wired into my acc wire pretty much? I couldnt find too many details but if i do get one i wanna cut out the dash and sort of flush mount it in. Can this be done with the stinger ones?
So could i actually just tie it into my amps power and ground? Is that safe? And my acc wire from my HU pretty much?
yup.. pretty much how you can wire it. or you can wire the ignition wire to your actual ignition instead of the HU remote lead turn on. cause if you ever turn the radio off and still want to read the voltage you will still be able to with your car on.
yes you are 100% correct
Im around nashville/rocky mount area. I think imma get the volt meter and get some 14g wire and just run it back to my amp and tie it into that power and ground. Id ground it seperatly but the resistance shouldnt be an issue should it?
i connected power/ground to the amps power/ground.
Mine's kinda flush mounted, i basically just made a front plate out of plastic (using a dremel), spray painted it black, and stuck it in a pocket on my dash (the knob on the left is my bass remote knob):
I like that, it looks very clean and stock.
Yea thats sort of what im going for. Mine will be mounted in my dash next to my usb ports, remote holder, and etc. Got a piece of mdf that i painted and replaced some of the factory trim with. Gonna cut it out with a dremel and see if i can get it mounted in there. Whats the best dremel bit for cutting mdf?
I Like Waffle
North Carolina
SPL Blazer
