How to hook up the illuminate blue lights on hifonics speakers?
  • 4
There is a 12 volt + and - terminal on the speakers for the illumination (don't confuse with audio + and - terminals).
Connect the - to chassis ground.
For the + terminal, you have several choices:
1. Connect the + to the remote output terminal from the head unit so the illumination is on only when the head unit is on.
2. Connect the + to one side of an on/off toggle switch and the other end to constant 12 volts (with 5 amp fuse) so you can turn on or off when you want (becarefull not to forget to turn off).
3. Connect the + to one end of an on/off toggle switch and the other end to an accessory switched 12 volt source (with 5 amp fuse) so you can turn the illumination on and off when the vehicle ignition is on only.
idk, if you'd want to run LED's off the remote output of your HU, how much current do they draw? If you go that route, I'd wire up a relay.
The LED's draw about 85 milliamps of current which is less then a standard Bosch relay which requires about a 180 milliamps to activate.
It will not be a problem for the remote output to activate the LED's and the amp turn on circuit.
A typical remote output is capable of about .75 to 1 amp.
152
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
marvinwillis
marvinwillis
Hinesville GA
Team Maxxsonics
maylar
    Jun 2, 2024
    Jun 1, 2024
