How do you guys running the big shit hide it? Im looking for the easiest way to get it out of sight. Car is a 97 Bravada, didnt see any spots to run it through the firewall, too much stuff in the way. Any suggestions?
Run it under the vehicle instead of through the vehicle //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
Seriously, this can be done safely as long as you keep the wire properly protected and secured, and IMHO it's much easier.
That's the purpose of wire ties and flexible conduit...Yeah, go ahead run the wire under the car. Have fun replacing a 30$ wire when it gets eaten by salt, or a stick that happens to be cruising on through..
I used automotive heater hose (like what's under the hood of the car) for protection in my buddies truck. You can get it at any automotive parts dealer (Autozone, etc). The stuff is great.....it's thick rubber with in-laid string, so it's very durable and will easily protect the wire. Plus, being heater hose, it's relatively heat resistant. Then used some of those screw-down metal wire clamps to secure the heater hose up out-of-the-way under the vehicle. Turned out real nice IMO. Wire was very protected and secured, and it was relatively easy to do. I also clamped each end of the heater hose to prevent water from getting in there.Im thinking this might be best. Any pointers? I figure to put split loom tubing on it, and use ties to keep it off the exhaust, engine, etc. Then a simple hole in the back of the car, to bring it in, sealed with a grommett around it. Should that work? Also, where can i get the grommetts for 0 gauge?
