how to achieve thsi ohm load?
  • 2
If you are using 1 dvc sub- the Dual 2 ohm model is your only option. You can wire it in paralel at 1ohm. It is not necessarily any cheaper to drive speakers at a lower ohm load; you just have to be sure that your amplifier is capable of handling the lower impedence.
take it easy,
-zane
the resistance (ohms) is simple physics...the two subs act as two resisitors in a single circuit.....say you wire the two subs in parallel at 4 ohms each...take 1 over the resistance (1/4) plus the other (1/4) and then take the reciprocal of that...in this case it is equal to 1/4 +1/4 = 1/2, in which case the reciprocal is 2...two subs at 4 ohms in parallel have a 2 ohm resistance...this formula will work for anything, just substitute 1 over whatever the resistance is instead of the 4 that i gave the example with...peace
It also lowers the amps efficiency and raises the current draw.
583
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
393
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
DB4Me
Gotta know as much as him
DB4Me
Portsmouth, nh
    May 24, 2024
