How should I wire 2-4Ohm DVC subs? Parallel or Series?
upschris
Installed my old ALPINE 7815 headunit the other day. Sounds as good today as it did 6 yrs ago! But not good enough. SO, I just ran SCOSCHE wires to behind the rear seat of Jeep cherokee for myALPINE 3522 BRIDGEABLE DUO-B-CURCUIT amp.I got 2,dual 4ohm DVC 500 watt MTX THUNDERPROS .wHO DO YOU RECAMEND I WIRE THEM? ???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Is your amp 1ohm stable? If you wire them parallel, you will be 1 ohm at the amp. Make sure first or your amp is gonna freak out and cause heavy draws, if not shut down or go into protect mode. If it is 1ohm stable, absolutely wire the subs in parallel. Will get you more power to the subs.......
I take it you didn't bother to look up the specs on the amp he is using.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
The CT's are nice, That Sundown is a a frik'n beast!
835
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
708
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
822
upschris
upschris
dENTON,TX.
bass_lover1
    May 31, 2024
    May 24, 2024
