How should I wire 2-4Ohm DVC subs? Parallel or Series?
upschris
Installed my old ALPINE 7815 headunit the other day. Sounds as good today as it did 6 yrs ago! But not good enough. SO, I just ran SCOSCHE wires to behind the rear seat of Jeep cherokee for myALPINE 3522 BRIDGEABLE DUO-B-CURCUIT amp.I got 2,dual 4ohm DVC 500 watt MTX THUNDERPROS .wHO DO YOU RECAMEND I WIRE THEM? ???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Is your amp 1ohm stable? If you wire them parallel, you will be 1 ohm at the amp. Make sure first or your amp is gonna freak out and cause heavy draws, if not shut down or go into protect mode. If it is 1ohm stable, absolutely wire the subs in parallel. Will get you more power to the subs.......
I take it you didn't bother to look up the specs on the amp he is using.
upschris
upschris
dENTON,TX.
bass_lover1
BP1Fanatic
BP1Fanatic
