How should I tackle wiring my door/rear deck speakers to an amp?
  • 4
Is it 12-14 the common spec for a driver or tweeter powered by a typical four channel amp. An exception is scenarios like Popwarhomie. 3k on a door sounds outright rad.
Like 800w total and 625w @4ohm x 4.
Not concerned about the wire itself just wondering if it sounds better to connect directly to the amp or if using the preexisting wire will work just as well as some new ofc
I'd like to go with a bigger amp but im not buying an alternator
The CT's are nice, That Sundown is a a frik'n beast!
575
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
524
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
618
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
931
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
danielbea122
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
