rikardob
Completely new to custom stereo and was hoping for some input on a perfect amplifier match for these Pioneer subs.
Link.
2 x Pioneer TS-SW3001S4 (12s) in sealed .65 cubic foot enclosures.
4 Ohms
Single voice coil
50-400 RMS
1500 peak
Sensitivity - 93 dB at 1 volt
Frequency response 20 - 230 Hz
I don't know if it matters but my receiver is a (let the hate begin, or don't because I already know it's coming) Sony CDX-GT700HD Link. If I remember correctly it has 1 set of standard RCAs coming out of the back labeled Mono with 2 volts of preamp voltage. The system is in a regular cab Ford Ranger and I'm using Hertz energy 2 way 5x7s in the doors for now.
Also please let me know if the amplifier choice is dependent on the outs my stereo has because I plan on upgrading receivers after a while.
Also...
A friend has recommended me this amplifier. I thought I needed a 2 channel amp that pushes 400 watts rms per channel at 4 ohms? How would one go about using this amp to power the two 12s at spec, or should I just look for a 4 ohm 2 channel 800 watt amp?
ZRS-7500DRB - Cadence 3600 Watt 1 Ch Competition Amplifier
SPECIFICATIONS:
1 Ohm RMS Power: 1 x 1800 Watts @ 13.8 Volts
* 2 Ohm RMS Power: 1 x 1100 Watts @ 13.8 Volts
* 4 Ohm RMS Power: 1 x 600 Watts @ 13.8 Volts
IHF-2002 Peak Power: 1 x 3600 Watts Max @ 1 ohm
* Two Z7500D bridged together = 1 x 3600 Watts RMS @ 2 ohm
Frequency Response: 10Hz - 400Hz
S/N Ratio: >100 db
Damping Factor: 119 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Thanks in advance for any input you may have.
Link.
4 Ohms
Single voice coil
50-400 RMS
1500 peak
Also...
SPECIFICATIONS:
S/N Ratio: >100 db
Minimum THD:
