how should i hook up my system
1loudbuick
Ok I just got a new amp today its a 800w Kenwood I'm gonna hook it to my ten inch Orion HP I was planning on bridging it to get 460w rms but I just found out my amp cant run bridged at 2ohms and that's what it would be r if my voice coils are wired in parallel right ?
not sure you didn't give enough info about ur subwoofer. is it 4-2 ohm and is it dual voicecoil? To answer ur question if the kenwood won't do bridged at 2ohms then u probally have to do it at 4ohms. figure out what your sub is and then follow a wiring chart to help you. You can find them online they will tell you different ways to wire your sub to get the ohm load you need. look for a way to get it to 4ohms or higher.
1loudbuick
1loudbuick
galesburg, il
queencitycycles
