How should I do it?
brewski
I have a Rockford 200 watt 4 channel amp and 2 MTX 200 watt RMS 10 inch subs. I am going to run the amp 3 channels, 2 channels to my door speakers and 2 channels bridged to my subs. My question is, should I run just one of the subs or both subs in series?
That's why I thought about just running one of them off the amp. But my installer says I should run both subs in series. I don't need alot of bass but I would like something to start off with and then get a better amp to run the subs with at a later date. So, any input on which way I should run them with this amp?
I'd do it and use it till you get a better one.. underpowering isn't bad.. as long as you don't max the gain.. making sure that it's not clipping would be good also..
brewski
brewski
Sumner, WA
brewski
Mike Mccabe
