You will be fine. You may want to go larger if you are planning on upgrading later (which seems to happen a lot).So according to that page, if I get a mono amp that gives out 1200 I should be fine correct? cause it says 4 gauge can handle 1400 from a class D....or am I wrong?
alright thanks a lotYou will be fine. You may want to go larger if you are planning on upgrading later (which seems to happen a lot).
