How many RCA cables do I need?
SpunkyXL
Hey,
I just ordered a new system for my Mazda3:
Alpine cda-9857 HU
Alpine MRP-F240 4 channel Amp
Alpine Type R Sub 10'
Alpine MRD-M605 Mono Amp 900 Watt
Polk DB570 Speakers
I just want to know how many RCA cables is needed to set everything up, and how big should I have them? I want to put my amps either in the trunk or under the passenger seat. And since I have 2 amps, do I need to order 2 amp kits, or is 1 enough?
Thanks..!
Hey,
Alpine cda-9857 HU
Polk DB570 Speakers
Thanks..!
you need an amp kit with a distrobutiuon block and then 3 sets of RCA's
One pair of RCA's for every channel. The front speakers are one and the sub is another = 2 pairs. Why do you have a 4 channel amp with one set of components??
I will connect the amp for the Front and Rears.. and The sub has its own amp.
Ok, pretend I have zero cables, just the equipment.. what would I need?
How many amp kits would I need? does RCA's come with the kit? Should I just get this, and this will get the job done for everything?
Rockford Fosgate 4-Gauge 800W Car Amp Power Kit
Model: CP4POS-06
http://www.bestbuy.com/site/olspage.jsp?skuId=7662228&type=product&productCategoryId=pcmcat30100050007&id=1134701342188
what type of rca's do I need? just the standart 16 ft rca cables? 2 male, 1 female Y?
Yes. They come in several lenghts. I have a Protege5 and it's about 9' to run them underneath the seat. If you are putting the amps back in the trunk, then you'd need the longer ones. Standard RCA's have 2 male plugs on both ends...that is what you want.
I'd just get 3 sets of standard RCA's. I'd run 4-ga with a inline fuse (guessing 140AMP) from the battery into a distro block (unfused block). Then, run 2 8ga out. 1 to component and, one to sub amp. Run the grounds. Done. As for the REM wire you can run a single one from the HU and loop it from amp to amp.
I am running the 240 also. Great amp!
Ok, here's what I'm going to order:
1 of
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK44
1 of
http://www.knukonceptz.com/productDetail.cfm?prodID=BC-1448
2 of
http://www.knukonceptz.com/productDetail.cfm?prodID=KLA-5M
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
SpunkyXL
SpunkyXL
JerZ
ngsm13
