How many ports??
pacho
One of my friends has a F-150 and he will be making the cutout from his bed to the cabin for his sound system. His daily driver will be 4 15"'s and when he goes into competition, he says he'll upgrade to 8 15"s. The box for the 4 15"s will be firing up in a vented box (vents also firing up), each sub will get 100 in^2 port area and my question is can we just use one port with 400 in^2 port area or do we have to separate the subs in separate chambers and make each port separate for each sub?? Also-when you're looking at the rear of the F-150, what would be the better route to go, firing the port up at the rear of the F-150 or firing the port up closer to the cabin?? Thanks for all responses.
having a single port is fine. however, because of the size of the box, i'd recommend splitting it into two chambers. Each chamber would house 2 subs, and have its own 200 in^2 port.
PS, are you sure you can fit that big of a box in an f-150? because of that port area, the port will most likely be extremely long, taking up a lot of space.
2 chambers, so that would be 4 chambers if he used 8 subs?? We're making the calculations for the box right now and we'll probably go measure it later tonight or tomorrow afternoon.
-Edit-So would placing the port nearer the front of the bed or towards the rear of the tailgate achieve more decibels?
bump-we'll be building the box this weekend so do ya'll think the slotted ports should be at the tailgate or nearer the front of the bed??
pacho
pacho
S.C.
pacho
NorthFramingham
    Jun 30, 2026
