How many layers is enough?
cyber256
I'm fairly new at glassing and I'm planning on making two custom sub enclosures to fit into the back corners of my trunk (seperate from each other). The thing is the subs I'm going to use are 12" Brahmas so how many layers should I use to ensure a solid box? I was thinking somewhere in the neighborhood of seven layers but I wanted to get insight from anyone whos done similar work. Thanks
Dpends on the weight of the mat and or cloth you intend to use. I like kyntex biaxial 15 or 17oz myself for sub enclosures. In most cases it only takes 2 two three layers and you can park your car on it . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You can't say that without knowing thickness and weight of the mat, orientation of the lamination, and several other factors. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yes its true but its uselly around that size...(1/4-3/8)
so if you can get it that thick youll be ok...
i use really thick matt and i also use a resin thats 20 times stronger then the stuff you get at hardwhare stores, so that helps too...........
good luck
jamie
What kind of resin do you use ?? You got to let me in on this secret. I use good old west systems epoxy mainly. Strong enough for man but made for me //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif And for mat/cloth I use kyntex biaxial for sub enclosures cause I'm a lazy beeyatch and don't want lay 5 or 10 layers down. Two layers of 17oz kyntex biaxial, and even my fat arse can stand on it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i live in louisana were we have offshore rigs and platforms. so theres companys that build fiberglass water lines (12" f/g pipe) on these platforms...
they have to withstand hurricans and very bad storms in the gulf , so its made to be very very strong....
jamie
Yeah but what is it ? There's a local place here I used to work for, that makes fiberglass products as well. We were using an epoxy resin that was pretty much the same thing as I can get from a couple different places. But it was alot stronger due to the lay up techniques that were used as well as the curing process. I was just wondering man. Inquiring minds want to know //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
its a back door kinda thing....hehea friend of mine works there so he hooks me up, i just give him something to put it in.....
jamie
So it's like that eh? //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif j/k
I was just wondering if it actually was a different kind of resin. I got access to a bunch of different kinds. Always looking to expirament //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ramos - what kind of resin do you use?
where can i get it (from you?)
i just use crappy bondo brand resin, and its fugly color and it fairly brittle. also, where can i get that kyntex 17oz glass? its woven i hope? i hate matte.
how much do you pay for the resin you get? only place aroundme that has is it pep boys... or the internet. i was thinking of getting some clear resing (epoxy?) and using it for a project im going to do (needs to be clear)
any ideas\suggestions? pm me =)
thanks buddy.
I use a west systems brand quick drying medium epoxy ( marine grade epoxy ) I get it locally from a boat supply yard. I buy it buy the five gallon drum/ 1 gallon catalyst. And it runs me around $100 depending upon who's working at the boat store that day. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I get my kyntex from fiberglast.com, and everytime I order it I always get a couple yards more than what I ordered. And yep woven then the mat and cloth are actually stitched together. It's really easy to work with. Just don't try to make sharp curves with it. It's kind of difficult to work into extreme corners.
Clear resin huh, working with carbon fiber are we //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Clear casting resin is what your after then. It dries crystal clear and pretty hard. People use it for craft projects and what not. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
cyber256
cyber256
Frozen Tundra
ramos
