How many CVR12 can be set to a Kicker 1500.1 ?
thats a good amp, with the 1500.1 you could do-
(2) dual 4ohm cvr 15s,
(4) dual 4ohm crv 10s or 12s,
(1) dual 2ohm L7 15,
(1) dual 2ohm cvx 15.....
theres really alot of possibilities
thats a good amp, with the 1500.1 you could do-(2) dual 4ohm cvr 15s,
cvr12 2 ohms dual voice coil how many can I connect? thanks Slow for the time
you can run 4 dual 2s if the amp is one ohm stable just run each sub to one ohm then wire 2 subs to 2 ohms then the other set to 2 ohms then wire them together for 1 ohm load
thanks Pole once again ........... I see that you are from kicker team great! how many sub would you recomend? CVR12's or does 1 L7 would be enough
yea, I'm on the Kicker Team //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'd do three CVR 12's, will out perform one L7 12"...
Can I see your ride and system ? lets see that baby
I have a question .... CVR12 are 400 watts x 3 CVR12 = 1200 watts
is that how you do the math?
no sound system in this one, just an average blue Yukon like this one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Octavio
Octavio
Nic
Polecat
