How many Amps does an Amplifer need?
Generally it will state the amp draw in the manual or look at the fuses on the amp if it has any. So if it has 2 20a fuses it will draw around 40-50a MAX so thats the size of fuse you need to use.. I hope thats what your asking.
Didnt think of looking at the fuses. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
im trying to figure out a way to run a car amp from an 120v source, although it looks like it would be more expensive doing that than just buying a home theater amp. I wish i could use the amp from my home receiver's surround outputs because i dont use those, but they wouldnt use the subwoofer input //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I think i could probably use my computer to re route the outputs, im not sure however. If ever hook it up to a TV though it wouldnt work at all.
Thanks guys
400watts
@Bass-aholic
there is a link to the amp i was looking at, you could have just used that rather than asking.
Yes but you need a power supply that gets the proper amount of amps. I was thinking of a car battery charger but the one i saw was 10 amps, not even close to the ~30 amps i need.
Being a computer geek im thinking of buying a mid range computer power supply //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
for 80 bucks this does the trick
http://www.newegg.com/Product/Product.aspx?Item=N82E16817338015
but add in another 100 for the car amp and its 180 for the "amp", which i can get a good home theater amp for easily.
@azbass
less spam and more real posts //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Rudster816
Rudster816
Washington
Rudster816
