So 16v would fry my computer even if its just for a burb then turn it back down? The reason Im asking this is my one buddy had a Ohio Gen Alt and it went up to 18v and when he would burp it he would crank it all the way up and burp it and his car was fine.. But I also understand all cars are diffrentI just wanted to address the fact of you wanting to run 16v from your alt to charge the batteries.This will fry your vehicles computer.I wouldn't run any higher then 15v.
Um I didnt ask if they did?
I wouldn't do it.Its only ment to run on 15v max maybe.On older cars you may get away with a few blown bulbs,but the newer ones will fry the ECU.It can be done if you have a seperate 16v battery setup or a 12v battery that can tolerate that high of a charging voltage.So 16v would fry my computer even if its just for a burb then turn it back down? The reason Im asking this is my one buddy had a Ohio Gen Alt and it went up to 18v and when he would burp it he would crank it all the way up and burp it and his car was fine.. But I also understand all cars are diffrent
