How low do most songs hit?
It will be greatly attenuated...the sub will still try to play it, but won't be able to play it anywhere near the proper levels.
Baroque music is the lowest that I know of, dipping into the infrasonic...large pipe organs are capable of playing sustained 16Hz notes, not sure how many people's systems can do that sort of reference level in their homes though //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
do you have a link or something to prove these infrasonic and 16Hz tones you speak of..... //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I've had the "chest poundin'' bass, I'm ready for the "kicked in the nutz" bass...
http://www.google.com/search?hl=en&q=pipe+organ+infrasonic
I can tell you from personal experience it's eerie as hell...I've delivered flowers to enough weddings at Duke Unversity's Chapel when the organist was warming up. Sub-20Hz tones at those sort of levels are really something //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
on those built in crossovers, I've found that the bass in the music in general sounds best when its set around 80 Hz.
Completely dependent on your equipment. It might sound best at 50Hz, or it might work at 80.
Alright, so a sub that doesn't respond lower than 40 hz isn't very good, right?
Generally, you want the sub stage to handle the bottom two octaves, from 20 to 80Hz - around which point sound starts to become directional. You don't want to be able to localize those lower frequencies.
Depends on the enclosure you put it in...since it's only an 8", I doubt the low frequency extension would be there - unless you stuck it in a folded horn or something.
True reference levels down low require lots of cone area (think 18") and lots of amplifier power. That's why the THX rating for LFE is so high - it simply takes a lot of displacement to move that much air.
Justinw303
[Space for Rent]
Justinw303
Silver Spring, MD
AndonD454
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
