How hot should an amp get?
logan963
I've recently switched from a hifonics brz 1200.1 to a JBL GTO 2400.1, now the hifonics never even got warm, but this JBL gets pretty hot and Im not pushing it near as hard as I was with the hifonics. I know certain amps get warmer than others, I have a jl slash v2 300.4 and it gets pretty warm, but not near as warm as the jbl does
I have the 1400 and those amps draw a tremendous amount of current. I wouldn't worry about it as long as you can keep it feed. I'm not even sure if they're class AB or D
Pretty sure its a class D
---------- Post added at 04:57 PM ---------- Previous post was at 04:57 PM ----------
When I had a jl it never got hot?
All the JL's I have had get pretty warm
No amp should run seriously hot.But It is good practice to run it a cool as possible.If it gets hot enough it should shut down/or blow a fuse,but fans are cheap,and move quite a bit of air.Its your system. So if you feel as if its running too hot,check your wiring configuration for proper ohm load,and make certain you are feeding it with the proper electrical,and make a decision weather to place a fan on it or not.Ive ran old school amps so hott back in the day I could feel the heat up front,on some old coustic 380s on my subs,190s on the mids ect.
Make sure you are not running it at a load its not stable at. That JBL amp is only stable at 2 or 4 ohms so make sure everything is wired correctly.
Lol little late bro. it was because of voltage drop, already fixed the problem
Yeah I just happened to see this lol I knew I was late but you never know! I was having the same issue so thought maybe I'd be able to help ya out. I'm getting voltage drops too... How did you fix it? Big 3?
yep, and I ran dual power and grounds
I'm planing on doing big 3 soon so hopefully it fixes it completely cause I also hooked up my cap and it helped a little. What do you mean by dual power and ground?
All a cap does is put more of a load on your electrical system. I would remove it.
ya, no caps. My amp has two ground and power imputs
logan963
logan963
Dallas, TX
SounDrive
