How do i lower the bass in my speakers?
So ur sayin to turn down the adjustments for the lower frequency ones?
If you need to. Say a voice is screaming at you and you know it's supposed to be lighter, lower the band that's around that frequancy.
A snare drum is overpowering, lower that frequancy
slowly play around with each frequency. When i first learned, i just completely lowered each frequency individually and see what went missing from my music and slowly learned what each frequency sounds like and then set the EQ to what sounds good.
ahhh the first step into the world of car audio //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif good luck man, all the infos right here haha
It also lowers the amps efficiency and raises the current draw.
620
NVX X Series and V series are pretty darn good for the money all the way around.
It confuses people who don't understand electronics and so they repeat it. I know you know better and i hope new people can learn correctly.
I would clean the paint off that location and use two washers to sandwhich the ground wire to secure a solid connection and use a bolt rather than...
27
Usmcgrunt471
Usmcgrunt471
Vancouver, WA
brafferty
    Jun 1, 2024
    May 31, 2024
