Usmcgrunt471
I just put a new Sony deck, 4 channel amp (hooked to factory speakers), sub amp and 12" sub in my car. The last aftermarket deck i had had bass/treble/mid straightforward adjustment. This deck has EQ10 adjustment and each setting has this jibberish
Band 1-32Hz
Band 2-63Hz
Band 3-125Hz
Band 4-250Hz
Band 5-500Hz
Band 6-1kHz
Band 7-2kHz
Band 8-4kHz
Band 9-8kHz
Band 10-16kHz
And the volume on each is in 1dB steps, 6 up 6 down
On a regular deck i usually have the treble one click below max, and the mid 2 or 3 clicks up from 0.
How do i lower the bass from my speakers? My sub is hitting hard but wen i turn my volume up past 18, the bass in my front & rear speakers sounds like its gona blow em up.
Thank u in advance for the help!
Band 1-32Hz
Band 2-63Hz
Band 3-125Hz
Band 4-250Hz
Band 5-500Hz
Band 6-1kHz
Band 7-2kHz
Band 8-4kHz
Band 9-8kHz
Band 10-16kHz
