How do I hook up speakers/tweeters without a crossover?
[quote=>>SQL
Your speakers have built in 6db crossovers on them.
What is it you want to do? Me personally I would run the tweeters from 2 channels of the 4 channel amp and the mid woofers on the other 2 channels.
Yeah I could do that. I was planning to run 150x2 on the amp, but doing it this way would give me better control over the loudness of the tweeters, because the main reason I'm getting the bigger amp is to get more mid-bass out of my woofers.
This brings to to another question. I'll be using a DMM to set my gains, but how would I find out what RMS my tweeters and woofers can handle independently?
cut out the in line crossover, its pretty simple. then you can run them how you want. when you cut it out just leave some room when you cut it to reattach it if you sell them later on.
I would set the level for the mid woofers and then adjust the gain on the tweeters until it sounds balanced. You should not (IMO) use a DMM to set the level for the tweeters. Running each on separate channels allows you to adjust the amount of HIGHS that works best for your install.
[quote=>>SQL
Yeah. Since the amp is 75 watts per, I would probably blow out my ear drums if I ran the tweets until I heard distortion. Haha.
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
If you have multiple amps you do not need to run a power wire from each amp to battery.. You can have a single run of wire with a distribution...
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
sjv13
StayStrange
sjv13
Lansing, MI
sjv13
    May 18, 2024
    May 16, 2024
