How cold is too cold?
K_Watson
It got down to 9* F here the other night and it has averaged >30* F for the last few days. I turned off my subs when the temps dropped, until today when it reached above freezing, but the temps are going to go back down. I am worried my system might be damaged if operated in the extreme cold.
When is it too cold to operate a system?
generally, when it drops below freezing, you'll want to allow your vehicle to warm up a lil before running your system... your subs/amp will create their own heat, so they will take care of it from there
don't worry about it man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
granted i usually don't push my system right away when its cold (or ever), i give everything a few minutes at lower volumes first.
It was 70* down here in bayou country //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
***** to be you guys.
nah, i love the cold. Once it gets above about 65 i pretty much have constant swamp-ass and i wish it was winter again //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
this is too cold, from two nights ago
WEAK
OP I'll play my stuff on half volume so the sub is at least moving a little bit, and then after a few minutes and the car is a bit warm I can turn it up to full tilt without issues
one good thing about cold weather, is the extra voltage!!!! lately its been above 14.7volts.. heres from a little bit ago tis very nice. when its warm/hot out im only running like 13.8-14v
[/img]
IDC how cold it is.. I get right in & beat the **** out of everything. Resistance is down, dBeeez are up.
My alternator approves this post
---------- Post added at 01:36 PM ---------- Previous post was at 01:36 PM ----------
^^^ beat me to it mofo
[/img]
14.7? What a ****. I don't see anything above 14.1 even if it's below zero //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
sorry //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif the alt im using is all funky but im not complaining.
From my collection a Pyramid PB401a amplifier from 1986. Class AB amp claims 100 watts per channel. Bridgeable and has separate gain control for...
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
K_Watson
K_Watson
Indianapolis, IN
stocker08
Decebal
    Jun 10, 2024
