how bad is .5 ohm
because if you follow that formula i wrote on the other page, anything above 20 volts on your output is clipping. Have you read anything ive been writing?
This is only with that example, its going to change with different equipment obviously.
Umm, no. How is anything above 20v clipping?
That formula tells you that if you want 100w's output than your output voltage should be 20v
That formula tell you that if you want 100w;s output than your output voltage should be 20v
You just answered your own question dude. Thats your MAX output before you start clipping. Think about it...
dude its not tuneing to clipping. once again its something that was phrased wrong i think.
the way this works
the dmm gives you exsact numbers, so that you can set it to a frequency well below cliping( so you dont blow shit up=)
then if your unhappy with how hard it pounds and you really want that exstra little bit take the time and effort to go to a shop with a 5000 doller tool to set it perfictly
Heres whats going through my mind right now.
Why couldn't you just change that equation to 150w?? 24.5v... Thats more than 20v.. So then you would say anything above 24.5 is clipping???
So your going to try and push 150 watts out of a amp that only has 100 watts to give?
Yes, thats clipping BTW.
iv seen lots of difrant formulas man 20v is low, but at the same time you want it low you dont want to just go nutts
i just wanted to see if i was going to like it at .5 if i did take it to a osiloscope
if you want true preformance put it on a osiloscope
rumple4skin
rumple4skin
mo
Haunz
Mike Mccabe
