Joseph7195
Walkin Tall
Hey man, thanks for the input! but i have done the big three including a ground running from Alt case to the frame.I had did a update in a post and found that under the hood, even with the hardest hitting songs my battery stays above 13.9 at idle. While i measured at the amp voltage i was getting 10-11v and on the same part on the same song while measuring at the battery, i was getting 13.9v-14.2v. So i dont think the probably is under the hood anymore. it has to be somewhere between the battery and the amp connection. Or the amp its self (gains or grounds) I have KNU 4 guage wire with a 80amp fuse on around a 6ft piece or wire, i dont think i should be getting that big of a drop, im only running the amp at 2 ohms....
On a side note though, i will definitely take a look at that and sand some paint off and bolt it to the frame, just for the sake of having a better ground
YOu're exactly right, you shouldn't have as much voltage drop at the amp as you are having. I would take the battery out tonight too, and let it just sit overnight. And in the morning check the voltage, you may just have a bad cell in it, and the alt is charging correctly at 14 volts, but the battery never charges all the way.
You will never go wrong upgrading your battery. I ran around 2500 watts with a Duralast 1000 amp AGM up front, and an XSTATIC 2,000 amp battery under the bak seat, and would only dip below 12 volts during a competition burp run for 30 seconds.
