los33
Car Audio G
If its knu cca id stay at 80 amp as thats its max rating.I will most likely ordered it when i order more wire again, there was also like a split in the wire jacket from melting, like i said though it might of been caused from the loose connection or because of what we had said earlier. So go for a 120amp fuse?
Or you can do what others have said and use the fuse that doesnt blow.
Not everyone uses the same setup, pretty much just what works best or is safer.
I wouldnt even worry about fuses either in lower power setups like this.FUSE??? All this talk of the fuse possible being a cause is strange to me. Has any body EVER measured varying voltage drops change from different size fuses?
I've done many experiments with fuses and always found fuses to ether work, or it blows. The only time a fuse caused a a voltage drop for me was right before it would blow. Personally I have always tried to use the smallest fuse i could get away with and it has never caused any voltage drop. I change fuses till i could get a fuse to blow from playing music then use the next size or two sizes up fuse.
Op, like mentioned before, your issue is most likely wire, wire connection points, or ground.
Larger power is where you find most resistance drop from fusing.
Especially when you want near perfect voltage from front battery to back battery.
Sent from my draconis using Tapatalk
