Highoutput Build
Well I'm working on getting a system in my tahoe Right now I have 2 basic Low power 15s. I'm looking at getting either 2 fi 18s or 2 ssa evils could do 4 but what I want it's going to be a daily driver but I want something that's gonna be heard like a system that before u turn the corner it's heard I want that deep sound very deep bass that shakes building thinking whether a wall in the back or just a regular enclosure any recommendations ?
JVC HU, Pioneer 8601, 2 sundown e 15 v3's 5.8 cf ad ported tuned at 34hz
yeah if u just get a little bigger box with more port area built I think u will be happy with it and if u do 8cf box u could switch subs out with higher end ones later after u do other upgrades.. I think u get more and much better sound when u replace hu..
I thought sonic did a bench test it's 1300 @1ohm it just said 2600 but doesn't put that
there is no dyno on the 2600.1 Its a 900 watt amp at best. If you have a pre-built ported box then its A LOT smaller than what you specified.
5.8 cubes is what I'd put a single 15 in if I wanted deep lows.
I said when you first posted last month that the box was a hunk of ****. Way too small, WAY lacking in port area.
I suggest;
1) build the proper box first. It will be a huge gain
2) if you like the Es at that point, add 2 more e15s. This will be cost effective and wont require 8k of power. 4 e15s on a 2-3k would still be rowdy
I suggest;
So 4 e's on 3k in a custom box?
But i think I gained a few dbs over my pioneer 8601 it's louder and hits the lows better
Learn to walk before you try to run. Put those e's in a proper box with a huge port and see what happens. As others have said, you can add more power or upgrade subs later if you build a proper box now. A pair of 15s can take you a long way if you give them enough airspace.
Thing is I stay in Pompano beach FL and I have to find people upstate to build a box and shipping is 200+
So your answer was to buy 1000$ worth of new subs and put them in a prefab box hoping for better results?
Go shopping for tools at a pawn shop, Florida is full of them, and build it yourself.
If only I had the skills ?
yahhhyahhh
yahhhyahhh
Miami, Florida
yahhhyahhh
