I get you!It is late Sunday dude... Re-read the thread and use those starting points then listen and adjust and be critical... sometimes loud is not good... a CD will not help you... Rockville!... HA!.. Good night...
Yes, I agree and thanks for the advice.You're kind of hosed on the HPF 100hz thing. That's a drawback of many of these cheaper amps. There simply isn't an effective method to cover 50-3000hz with a dial. Even at the 1/8 point on the dial you'd be at 300hz plus -- assuming it's a linear/accurate dial and it probably isn't.They're trying to give the option to filter any type of speaker including a tweeter. What they need there is a multiplier switch to make that dial either 5-300 or 50-3000, but that costs money and this is a low cost amp.
Basically, someplace barely off the stop at full counter-clockwise is where you'll want to set it.
download xplicit audio ultimate car app on your phone there's a test tone generator. Play the tone, adjust it until it starts fading and you are at the right spot.And how do you know where 100 is on say a hpf.It's easy on some of them as it's just 15hz to 55hz.
So it's easy to divide it up and estimate where the 35hz is.
But the hpf is 50hz to 300khz. That's more difficult to guess where 100hz is!?
no like 24 if u are really sure it's tuned at 30hz after sub disp., if u aren't sure i'd just set it a tad below 30 or at 30 for that matter.. u can set at 30 play deepest bass u have and turn it down just a tad every few seconds if u don't hear and distortion u can probably leave it at 24-25hz..Just chiming in here because your talking about what i have a question about. If my box is tuned to 30Hz and i should set my SSF 1/2 an octive lower than that I should set it at 15Hz correct?
so how the rockville sub work out?Thanks.I tried that but it didnt drop off like I thought it would.
In the end I just set the audio up so it sounded good and left it at that!
easy math, 75% of box tuning aka for you 22hz. done.Just chiming in here because your talking about what i have a question about. If my box is tuned to 30Hz and i should set my SSF 1/2 an octive lower than that I should set it at 15Hz correct?
