high and low pass filters and Subsonic filter.
neil4374
Hey,
Well thanks for all you advice guys with my install. It sounds great. I still am confused in some areas especially high pass filters ,low pass filters and subsonic filters. I have enclosed two photos of my amp.
I understand what the above are for but the confusion starts when I look at the hz range of those filters. If the subsonic filter for the sub is 15 to 55hz and the low pass filter is 5ohz to 250 hz. why do the overlap each other?
its the same for the 3rd and fourth channels lpf and hpf
Sorry if this is dumb? Maybe I am over complicating things
View attachment 26556296View attachment 26556297
They don't overlap. You use them to create a bandpass. What you want the sub to play.
Subsonic covers the low end and will be set according to the subs enclosure. If it's sealed it can be opened up, low. If it's ported you set it 1/2 octave below the boxes tuning. LPF covers the top end. You set it just under where the mid bass speakers pick up. That one takes some listening to get dialed in.
HPF is for the mid bass.
Many thanks for looking at that for me.
Ok understand the ss and lpf.
The sub setting doesn't have a high pass.
Do you mean the high pass on my front component speakers?
Many thanks for looking at that for me.Ok understand the ss and lpf.
Correct. It's their low point cut off. No filter is a brick wall it's just a slope. Meaning it will start to drop off past that point.
Like the sub. If the mids play to low they will break.
Sorry I just want to test my understanding.
So if the ss is 35hz and the lpf is 80hz as I correct in saying the sub
Will only play between sounds between 35 and 80hzbut taking into account they slope off at 35 and 80
Yes, you are basically correct but every x-over has a slope... 6 db is gentle with a gradual rolloff... And then there is 24db which has a steep slope... These are guidelines and once set-up a fair amount of listening and adjusting has always been my favorite part... Mid bass has always been the tricky one for me... Of course once it's sounding good ... I rebuild... Always lookin' for more!
And how do you know where 100 is on say a hpf.
It's easy on some of them as it's just 15hz to 55hz.
So it's easy to divide it up and estimate where the 35hz is.
But the hpf is 50hz to 300khz. That's more difficult to guess where 100hz is!?
Many thanks:)
I am getting there!
And how do you know where 100 is on say a hpf.It's easy on some of them as it's just 15hz to 55hz.
Play tones. Move the filter until that tone starts to fall off.
Now you see... You have to listen and adjust... pay particular attention to those low mid freqs... subs are easy just lowpass them at 80 to start... HPF is harder for mids... I've set them as high as 200 hz then brought them down... once you hear distortion, back offf and adjust your subs lowpass to blend those freqs... Ideally you should not be able to audibly locate the sub... Rockville?
Thank you, yes rockville
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
293
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
897
neil4374
neil4374
los angles
Jeffdachef
