hi/low converter help
nik8625
02 Montana. Got everything hooked up but no sound. I had to use a hi/lo converter trying to keep it looking like a factory stereo but cannot get sound through the rca's, I tried splicing into the front then the rear speakers from the rear of the deck both converters where grounded during install, they are 2 channel. One of the converters has the gain control the other doesn't (yes it's turned up). I have bought 2 now including rca's hoping it was just bad wires. Kicker 550.2 amp, just kenwood subs 1200 peak. Power light is on tested amp in friends vehicle, works fine. Just don't know why I cannot get sound through either converter with either set of rca's.
Put amp in HIGH level mode and run speakers directly into RCAs so you can test if amp/subs are working first. What model/make LOCs did you try?
You can use a 2 channel one and just use RCA Y cables to go from 2 to 4 outputs Do yourself a favor and get one with a line driver built into it...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
459
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
624
nik8625
nik8625
United States
Jepalan
    May 20, 2024
    May 20, 2024
