Hi First Time poster. Question on Amps
Hello, I need some help figuring out what amp(s) I need to support my current setup.
This is my Current Setup. TOTAL of 3 Subs.
SONY SUBS X 2
Manufacturer Part Number XSGTX121LS
Manufacturer Sony Corporation
Product Model XS-GTX120LS
Product Name Xplod XS-GTX120LS Woofer
Impedance 4 Ohm
Driver Type 12" Polypropylene Woofer
Minimum Frequency Response 42 Hz
Maximum Frequency Response 1 kHz
RMS Output Power 300 W
PMPO Output Power 1000 W
PIONEER SUB X 1
RMS Output Power: 300 W
PMPO Output Power: 1300 W
Driver Type: 12" Polypropylene Woofer
Minimum Frequency Response: 20 Hz
Maximum Frequency Response: 220 Hz
Impedance: 4 Ohm
Sensitivity: 95 dB
*EDIT* - I know they're not the best subs but this is in a ford ranger XL 1996 truck(standard Cab)
next question is what would sound better if i shouldnt mix it.
SONY SUBS X 2
Impedance 4 Ohm
or 1
PIONEER SUB X 1
Impedance: 4 Ohm
They're pretty comparable subs for both optimal sound quality and output.
Naturally, the pair of Sony's would have more potential for loudness than a single Pioneer.
You'd be looking for a mono amp around 600w rms at 2 ohms.
Tons of options. Some so-so stuff in the $100-120 range or something reasonable quality for $150+
Soundstream PN1.650D Picasso Nano 650W Class-D Monoblock Amplifier
MB Quart OA750.1 Onyx Series 750W Monoblock Amplifier
Alpine MRV-M500 V-Power 500W Class-D Digital Monoblock Amplifier
you will wire the pair of four ohm subs in parallel for a 2 ohm load.
if you added the third in parallel you'd need an amp that was 1 ohm stable.
i agree you want to avoid mixing sub types and brands. but if you were dead set on it, i recommend separate sealed chambers for each sub.
this amp would give you the flexibility to run either 2 or 3 subs (and it's in stock)
Precision Power PPI BA2600.1D 2600W Class D Car Amplifier
how it will sound (2 or 3) is highly dependent on how you build the box and how it is sized. getting adequate airspace is important and you'd rather have 2 subs with proper airspace than 3 subs with too little airspace.
have you measured your maximum top and bottom depth, height, and width to calculate what available airspace you have?
something like this
http://www.netaudiowf.com/store/ford-ranger-ford/1999-2011-ford-ranger-standard-cab-sub-box-full/
the same way.
having a piece of wood btw them doesn't change how they'd be wired.
Whether you connect your wires directly to the sub or through a terminal cup -- the subs are still 4 ohms and you still need to connect them parallel to get 2.
I ended up using a amp with these specs (Brand and model are slipping my mind at the moment)
Maximum Output Power: 1 Ch x 600W at 4 ohms
Maximum Output Power: 1 Ch x 1100W at 2 ohms
Rated Output Power: 1 Ch x 330W at 4 ohms (1.0% THD)
Rated Output Power: 1 Ch x 600W at 2 ohms (1.0% THD)
Low Pass Filter: 50-300Hz (Variable), 12dB/oct
Frequency Response: 10Hz-300Hz
with these Sony Subs X 2
Tech Features Impedance 4 Ohm
Tech Features Driver Type 12" Polypropylene Woofer
Tech Features Minimum Frequency Response 42 Hz
Tech Features Maximum Frequency Response 1 kHz
Tech Features RMS Output Power 300 W
Tech Features PMPO Output Power 1000 W
And like i said I dropped them down to 2 ohms
Anything should be changed? Also is it true that 4 ohm subs down to 2 wear more and tend to die quicker? or that a myth?
It's not a myth. It's just wrong. Myths are "widely believed to be true".
The fact that the subs are wired in a particular way to achieve a particular impedance has NO impact on their durability. The primary factor in their durability is the power they're receiving.
If they were wired in series for 8 ohms to an amp that does 1000w at 8 ohms - THAT would be a threat.
The fact that they're wired for 2 is fine. More specifically, the fact that they're getting ~300w each is ideal.
The XM-ZZR3301 should work well.
So I know you guys said don't mix subs.
Would it make a difference to put another sub in that is running at a different ohm? Since I have running them at 2ohm to now run a 4 ohm sub(that pioneer?) I'm also talking about on two different amps.
MrFordRanger
MrFordRanger
NorthEast Ohio
MrFordRanger
