Help
Billy Wilkerson
CarAudio.com Newbie
I'm currently have two pioneer GMD 9701 subwoofer amplifiers I currently have two pioneer 3020 pro samurai subwoofers I need to know are they perfect for each other as far as the amps and speakers or should I go a different route for the amps I'm currently running one on each subwoofer but when the base hits real hard it clips into protect mode and it comes right back on when I turn it down
How'd you manage that? It comes back on when you turn down the volume? The volume control knob are equipped with variable resistors. Turn the knob on and increase it, the volume goes down because the current flowing through it decreases. Turn the knob down a bit to half way, the current then increases. Volume up again. The electronics behind protect mode is that the semiconductors are in saturated mode way too long, the amplifier then shuts down at that point. No way to reverse it after the diodes and mosfets are in saturation mode for too long. It should be in the active mode, or cutoff mode. On or off, is the cuttoff mode. Referring to these variable resistors, the cutoff mode. Have to get it fixed once in the protect mode.
There's a zener diode or the zener break-down ( PIV ), peak inverse voltage. But these zener diodes operate in reverse bias for not a long time. After that they break down. Called the zener peak inverse voltage diode breakdown point. It is referring to the avalanche effect. The point the amplifier is about to break down. At which point the amplifier is already in saturated mode and signals a protect mode. Zener peak inverse voltage voltage is peaked or maxed out in the reverse bias direction. As it relates to op amps and the linear amplifiers talked about here.​
Your amps are 1200 watts RMS and the subs can handle 1800 watts RMS. You're find there. It sounds like you need to tune the amp better. What is the lowpass filter set to and what kind of box, and box size, are the subs in?
Billy Wilkerson
CarAudio.com Newbie
Billy Wilkerson
Florida
Old_Slapper
