help with soldering
and its not real hard to remove solder with the iron.. and you dont have to drop the freekin board like whats his face said. sheesh
no, you DONT have to, but if you dont have a solder sucker, or desoldering station, or solder wick, then its a perfectly reasonable method //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
This is part of why P2P construction > * //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The solder wick (braid) works better than any ******* tool I have used for removing solder. The heat and tap method works too and it won't hurt the board or the components on it. Of course, you don't really have to remove the solder to replace the component. If you are quick with the iron you can heat it and slide the legs of the component through it.
Twistid
Twistid
in a space out of sound
Death By Bass
Mike Mccabe
