Help with setup?
Originally posted by smokeoff No. American made ford taurus. And I was just hoping that I could get some wiring ideas.
not to flame you but you put neons on a ricer i hope for all that is holy that you get ***** slapped then realize it's stupid.
adam
Beauty is in the eye of the beholder... I helped my kid put neons on his Ford truck and it looks kinda cool at night.
The wiring I did is simple. I picked a spot kinda in the middle of the truck (underneath) where the wires from all 4 tubes would reach. The black wires went to a ring terminal and got grounded to the frame. Tied the red ones together then ran an extension wire into the engine compartment then thru the firewall (grommet). Ran this from a 2 amp fuse and switch. Think I stole power from the cig lighter. They don't take much.
I used tiewraps to hold the wires up under the body.
Thanks maylar.
Hey bumpin. U would be suprized at how much of a conversation piece an under body kit is. Pull up to play some hoops turn the car on and match people (that includes people of the female species) come over to talk to you about it. Used to do it all the time with my cousins car. But now hes off to college:( and its up to me to keep up the car audio and accessories //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
O. good luck with them MB Quartzs too. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can also find an empty fuse space in your fuse panal that is live all of the time, and crimp a spade terminal to your wire and stick it in the fuse space. Then run it to a fuse and switch. It saves going threw the firewall. I did it and it works great. The lights don't take much power at all to run. Have fun runnin the wires though. They are a pain in the ***.:p
use some relays. and prob thinking of wiring them in parallel so all of the lights get the same voltage. then just connect one of the end of the relays to a switch so u can turn on/off
actually a tight car will bring more than under body neons. oh and on the quarts thanks sold em today:D.
adam
smokeoff
here's my 3 cents
smokeoff
Cambria,WI
bumpin_blazer
