Help with setup (noob)
Hey guys
My entire set has arrived on time two days ago and was installed yesterday.
And I must say.....W-O-W! //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
The sound is as perfect! It's as clear as water! No disturbances or noises what so ever! It sounds amazing when its loud! Usually when I hear loud in other cars, the sound is sometimes choppy a bit or kind of fuzzy. Not here though!! It's perfect, music to my ears //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you all for recommending the right set up. I'm extremly satisfied.
By the way you were right about ditching the rear fill, I hella don't need it.
Guy //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
So what did you end up actually getting? And if you got the PG RSd65cs component speakers, how are they installed? Where did the tweeters get mounted?
I'm guessing you had a shop do the install for you? Or did you do it yourself?
Glad you like your system!
-- Kevin
Thanks!
Yeah, I had a friend install it for me.
The tweeters are placed in the front corners of the door under a plastic cover made by Mistubishi especially to hold tweeters. They are connected to the crossover where each crossover is placed behind the door near the speakers.
And the crossovers go to the amp as well as the subwoofer. That's about it I think (if I understood correctly) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
Guy
Gwee
Gwee
NJ
synikalt
