*help* With Amp And Sub Connection
Do you have the 2,4, or 6 ohm?
JL500/1
Rated Power:
500 W RMS @ 1.5 ohm-4 ohm
If you have the 2 ohm your gonna have to wire it in series, other than that you should be fine wiring in parallel. It should be a good match.
Im pretty sure they are 4 ohm subs. If you run them parallel it will be a 2 ohm impedence load on the amp. Seeing as it is a mono block amp it should work perfect. Set the gain btween 1/2 and 3/4 for good clean power.
JLW3
JLW3
seattle, wa
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
