Help wiring my subs to my new amp?
RodKnockJunk
CarAudio.com Newbie
5
USA
I have 2 SA LCS 12s powered by a SA SAM500 amp. I need some help wiring the subs together. The subs are DVC 4ohm 300watts a piece. The amp says it is stable at 1ohm but Ive heard 1ohm is not good for the amp. How can I wire both subs down to 2ohms and the amp be able to power them good still?
You have to wire either 1 or 4 ohm. One ohm will be fine.
You willl be fine. You will not be running full out all the time with that set up youll get a decent amount of bass nothing earth shattering by no means. From my experience with other SA products they handle more than rated hopefully still the case. Ive used the SD-2 and X series. I had a RF T-1000.1bd at 1 ohm on a single SD2
RodKnockJunk
CarAudio.com Newbie
RodKnockJunk
USA
tommydh
