Help wiring my new setup
Just got this Sundown SAE 1200d off ebay for 205$, think it was a good deal?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=330340496609
Its going to power the 2 12'' kicker cvr subs I just bought. They're 4 ohm dual coils.
How do you guys think I should wire them to the amp? (400 rms per sub//200 per coil)
I've got a 75x4 ea4100 eclipse amp powering my cabin speakers, with 4g wire//8g speaker wire. Do you think i need wire that big?
Do you think I should keep that wire or use it for my sundown amp and get 8g wire for the amp and just keep the 8g wire to the speakers?
If not, what gauge wire should I use for the sundown amp?
Also, I just bought a 140 amp h/o alternator (215$ off ebay).
Right now I have stock wiring, what gauge wire should I use for the BIG 3?
Thanks you guys, sry I'm a noob :\
Well wire the subs to 1ohm and just keep your gain turned down. if i was you i would get a 1/0 awg dual amp kit (Knuconceptz=$109) and it comes with the distro blocks so you will have 4awg to both amps. and for the Big3 use 1/0awg.
4 g to power main amp.
8 g to power subs
8 g to power small amp.
10-16g to power cabin speakers
0g run along stock wire under the hood
sub+---------sub+-----------amp+
sub- ---------sub- -----------amp-
Well For you sub wiring go here... http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Save that site for future reference for your own learning purposes.
Speaker wire 8ga wow.. 8ga on subs maybe but not on front stage speakers. 12-18ga is kool IMO Partsexpress.com has a really great sale on some good speaker wire right now.
Also 4ga is good to power the Sundown but i would go ahead and hit it with some 1/0 just in case u want to upgrade in the future.
For the Big 3 throw 1/0 at that also.
I already have the 4g wire to the small amp and 8g wire to speakers.
Is there anything wrong with running 8g wire to the small amp and 8g from the small amp to cabin speakers? I know 8g is big for cabin speakers but i got it a while ago and had no idea what i was doing and someone said "get this" and i got it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
So I would be good if I just took the 4g wire from the small amp and used it for the sundown for the subs?
How much wire should I get for the big 3?
Any1 selling some extra 0g they have laying around?
I already have the 4g wire to the small amp and 8g wire to speakers.Is there anything wrong with running 8g wire to the small amp and 8g from the small amp to cabin speakers? I know 8g is big for cabin speakers but i got it a while ago and had no idea what i was doing and someone said "get this" and i got it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Plenty being sold right now check the classifieds area. and u will have to go measure what u need for the big 3 your self unless u find someone with same car that can tell u what they did.
but u will need enough to do..
Alt to Batt
Batt Ground
Chassis Ground
Her is mines
did u not read my post at all? and get about 10ft, 15ft if its in a truck. better extra wire than too short. and remember dont take out the stock wire. run it along with it.
Well he could remove stock wire but its just unnecessary work.
ah i read on here somewhere that its best to keep it because the big 3 wiring is just to get more power and will add to the stock. oh well. its neither right nor wrong //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
yep.... every every bit helps cause they say power only flows on i think 2/3 of the wire. Like in My case i could have removed it cause it was all in the way i just decided to Mod the stock.
SocialStealth
New Jersey
SRim23
