Help wiring amp - JBL 600.1
  • 4
Actually, if this is the JBL BP600.1, then it is infact 1ohm stable (it just doesn't put out any more power into 1ohm than it does @ 2ohm).
Also, since the outputs are internally paralleled, you can not bridge the amp. Those aren't separate "channels", just duplicate "outputs" (yes, there is a difference).
PS, here is the owner's manual: http://manuals.harman.com/JBL/CAR/Owner%27s%20Manual/bp_om.pdf
But, we need to know what impedence the subs are.
Then just put one on each "output"...don't worry about paralleling them inside the box. With one on each "output", they'll receive 300w a peice
Good times pulling out the subs and putting them back in the way i used to have them. LOL Thanks for helping me out - somehow i had a feeling that it needed to be done that way.
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
975
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
Infinity2134
Infinity2134
Chicago, IL
Infinity2134
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
