help wiring a front stage
  • 4
how can i hook up 2 tweets and 2 mids like some 6.5s on each door panel to the front? without going active. i wanted to use a 4 channel or two 2 channels.. and not use back speakers. I have never dealt with components but want to design my own. I don't want to buy a set already assembled. i know about crossover points and passive crossovers but dont understand the wring process if i use passive crossovers theres only 1 tweeter connection spot not 2.. someone explain please lol
Connect them in series or parrallel on the same ouput (You'll want to figure out the resistance and match with your amp)
You'll hook two tweeters into the tweeter output
and two midbass into the midbass output - the final load will depend on which speakers you choose and which way you hook them up. Just match the amp and you'll be good to go. Why not go active though?
well lets say i have a 3 way passive crossover for each door in the front with 1 tweeter connection and 1 midbass 1 woofer. how do i run 2 tweeters (in parallel) to that 1 connection on the passive crossover? if i ran 2 tweeters in parallel to that 1 connection then id be missing a crossover point in between those tweeters before it got to the passive crossover itself. Does the passive crossover connection count for both the tweeters connected in parallel? same with the midbass connection, can i run 2 in parallel to that 1 passive crossover
---------- Post added at 02:40 PM ---------- Previous post was at 02:39 PM ----------
i may be just over thinking things i dont know but its got me confused lol.
once you change the load impedance on the passive crossover by wiring like drivers in series or parallel, you put the crossover points and rolloff/in out of whack and can likely cause irreversible damage,.. passive crossovers are built solely to operate at specific impedances
best thing to do is run two full sets of crossovers and drivers per door and wire the crossover inputs however you like
You can't connect multiple speakers to a single passive crossover unless it was designed for the combined impedances. Like if you parallel two 4 ohm mids the crossover would have to be designed for 2 ohms. Better to use 2 3-way crossovers and parallel them at the inputs so the amp sees 2 ohms but the crossovers see 4 ohm speakers.
Or... use 8 ohm speakers and tweets so when they're paralleled they respond as 4 ohms to the crossover.
You can match the impedence by using different drivers though, for example I have ran a passive crossover meant for a single woofer at 4ohms with two 8ohm woofers wired parrallel to create a 4ohm load. It sounded fine to me.. but that was to my ears so perhaps it isn't the best way to do things. I don't run passive anymore so it doesn't really matter anymore but good to know this information! Thanks.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
975
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
bassbaby94
san luis obispo CA
cfox10
    May 24, 2024
    May 23, 2024
